Old 09-27-2009, 09:07 AM
essasmallengines essasmallengines is offline
Default Hello from Barrie Ontario Canada
Hi I am a new member from Canada I run a small engine shop I just opened this year still on the learning curve but willing to share freely of what I know, for I believe knowlege is power and the free sharing of knowlege is powerful. I am looking forward to many interesting topics in the future .
Dan
Old 09-27-2009, 10:21 AM
RPalmer's Avatar
RPalmer RPalmer is offline
essasmallengines,
I was actually in Barrie once. It was my kind of place. Serene, beautiful, and sorta isolated. IIRC. Welcome. - Peace -
Old 09-27-2009, 12:24 PM
Dan! Glad to have you!
Old 09-27-2009, 12:40 PM
Dan:
Welcome to our Forum.......
Old 09-27-2009, 01:23 PM
papaglide's Avatar
Dan, welcome to the forum. Been through Barrie many times on the way to North Bay. Beautiful country!!!
Old 09-27-2009, 04:19 PM
MrMac's Avatar
MrMac MrMac is offline
Default greetings from across the gorge
Welcometo the forum dan,from wheatfield,N.Y. I do have a question for you,what would cause a lack of throttle control while an engine is running,it will actually run at a high R.P.M.,But,it fails to come down on slow position? thanks and welcome again.
Old 09-27-2009, 04:44 PM
Roblynn's Avatar
Roblynn Roblynn is offline
Howdy Dan and
It's so nice out.....I think I will leave it out!
Old 09-27-2009, 05:34 PM
Default Thanks for the welcomes
Thanks for the welcomes and a question from MrMac, I had a tractor come in , with a "lack of throttle control while an engine is running,it it did run at a high R.P.M.,But,it fails to come down on slow position" it turns out the customer tried to tune it himself and ended up with a trottle screw in backwards, some springs in the wrong holes and the jets were all miss adjusted, or it could be some dirt in the carb. Check your linkages for binding or sticking, look up the specs for your engine and check the initial settings as to how yours is set up.If you are comfortable cleaning the carb outside and inside that often clears up a lot of performance problems, let me know what works for you to get the throttle control back. I hope I have been of some help.
Old 09-27-2009, 05:36 PM
Dan,
Old 09-27-2009, 06:50 PM
IHinIN IHinIN is offline
Welcome Dan
