Old 01-13-2012, 11:53 AM
novaman_68 novaman_68 is offline
Default Replacing non-adjustable carb on 1872
I have a model 1872 with the junk non-adjustable carb, from searching the forums, I believe I can get a carb off a KT17 series 1 (but not series2) and it should be the ticket. Correct? I want to make sure to get the right carb the first time. I want to be able to adjust it as needed (in case there was any confusion) Any more info would be helpful, thanks in advance.
Old 01-13-2012, 03:20 PM
Also.....does the carb have to come off another Cub or can it come off anything with a KT17? (John Deere, wheelhorse, etc) Thanks
Old 01-13-2012, 03:49 PM
weaverama weaverama is offline
Before you give up on the Walbro just make sure it is really not adjustable. My Super has an adjustable Walbro idle and high speed jet. It runs that Magnum 20 just fine. I have a #26 Carter off an old K301 single but the cable linkage on the throttle shaft would need to be re-worked. It's hard to believe but the throat on the Walbro is much smaller than the throat on the Carter so I am not sure how it could be fitted to the Magnum. I was once told that the #26 Carter (Kohler) carb was too big for the Magnum twin. It would deliver too much fuel to each of the smaller cylinders on the twin on the intake stroke.
Cub 108
Cub 1650
Cub 1000
Cub 682
Super Cub 2072
