Old 04-13-2012, 04:56 PM
Ewilliams's Avatar
Ewilliams Ewilliams is offline
Default 125 NF hydraulic pump
Has anyone replaced the Shaft Seal (behind the pulley) on a nf hydraulic pump? I have a pump in good working condition but there is a small leak in the seal and I wanted to know if I had to take the whole pump apart to replace it. I've never taken one of these apart and don't know what is involved. I found a seal at ccspecialties for 9.00.
Thanks,
Earl
Original, 1512, ih 982, ih 682
Old 04-13-2012, 07:33 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Hydro repair manual
I'm pretty sure there's a service manual in the reference section. I got one for the hydro in my 123 there. Let your fingers do the walking!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-14-2012, 01:45 PM
Ewilliams's Avatar
I didn't see a service manual, only an installation manual. Thanks
Old 04-15-2012, 09:59 PM
IHinIN IHinIN is offline
I replaced one a while back. You might get away with just removing the pulley to get to the seal. I can't remember exactly how the seal was in there.
Old 04-16-2012, 06:42 AM
mmzullo mmzullo is offline
Pump seal # is CR 4911. Most put 2 in because they are thinner then the originals. I have a full right up in PDF format on rebuiling the aux hydro pumps. If you need it let me know. Its a big file.
Old 04-16-2012, 11:40 PM
Ewilliams's Avatar
yeah, I would like the file on rebuilding the pump. You can email it to me at snackpak@roadrunner.com.
Thanks,
Earl
Old 10-05-2012, 11:06 AM
hali11 hali11 is offline
I also would like the file. Please email to: seamonster11@hotmail.com. Thank you very much.
Old 12-15-2014, 01:36 PM
PaulF PaulF is offline
It appears I have a leak on my aux hydraulic pump too. Although it's not leaking from the shaft seal, it seems to be coming from around the up/down adjustment arm. Could I have the rebuild file too? pfosen@msn.com
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 12-15-2014, 02:33 PM
c69ss396 c69ss396 is offline
can you email the file to one of the mods so they can upload it to the site in the library section. It would be nice to have available from time to time.
Old 12-16-2014, 02:54 PM
I sent a PM to the gentleman that said he had the repair manual on file, but if anyone else has a copy I'd appreciate if it could be shared.
Paul F
Infantry Veteran
