Old 05-12-2012, 03:59 PM
cavmedic cavmedic is offline
Default 1450 No charge
Was mowing today and noticed my Amp gauge down in the discharge.
After I finished mowing , I checked the battery voltage .
I am only getting 12.3 v both WOT and about the same with engine off. ( I think it is seeing my battery voltage )
I checked the ac terminals on my regulator and getting something like 37 vac on WOT and only 12.3 volts on the DC pin of the regulator.
I have checked my ground and also my connections to the regulator .
I have a sneaky suspicion that my regulator is not up to snuff but was wondering if anyone knew of an automotive cross for the regulator.
Everything I am finding applies to the old square box style regulators .
My google searches are not yielding any results and i have tried numerous searches here but not getting the info that I need.
I do not feel like waiting a week for a web order as I want it fixed yesterday . Not to mention 70-80 bucks makes my sphincter wanna make a diamond out of some coal.
Old 05-13-2012, 10:21 AM
bkw3614 bkw3614 is offline
I have exactly the same problem with my 1250. Does anyone know how to test the regulator?
Old 05-13-2012, 11:09 AM
As found in our Technical Library........... V/R
I have never found a aftermarket substitute. You can obtain this V/R from your local Cub Cadet or Kohler dealer(s). If that is not possible, then our fine sponsors would be more than willing to send you one.
One thing to check on the Q/L's. There is a "firewall" electrical connector. The charge wire connects into this connector. You may have a bad or high resistance connection in the connector (Male or female portion). Don't ask how I know this....
PS: OEM Part: 41-403-09-----------> 25-755-03-S
Can Use: Stens: 435-081
Old 05-13-2012, 11:15 AM
I did check my connector. I'm going to do one more test tomorrow to double check my output.
I know my stator is good with the AC to the regulator on the terminals with regulator unplugged. To eliminate my theory of the 12.3 v seen at the DC pin , once started , I'm going to disconnect the battery and see if I still have my voltage. If I do , then I know the voltage I am seeing is indeed output from the reg , if it goes away , then I know i am definitely seeing my battery voltage.
Now when I tested the R across the coils . I came up with .2 ohms , which is a bit more than the chart suggests, but I know I am putting out AC , and will try the new regulator before I rip the engine off to install new stator.
Old 05-13-2012, 11:19 AM
I just can not believe the price
Old 05-13-2012, 11:40 AM
PM sent
Old 05-13-2012, 05:26 PM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
Stens sells the Voltage Regulators.
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
Old 05-13-2012, 06:27 PM
$30-$50 on ebay
Old 05-13-2012, 07:38 PM
EarlJ's Avatar
EarlJ EarlJ is offline
You can get it from NAPA in a pinch, they have to go to the catalog to find it. About $50 for a new one....
