Old 05-26-2012, 12:02 AM
jdroison jdroison is offline
Default 1811 leaking at hydro input shaft
stopped to cool off today and saw oil on the frame and deck. Took off the tunnel cover and there was a small piece of plastic wrapped around the shaft between the coupler and the front of the hydro. it was in there pretty tight but I got it all out with needle nose pliers and started the engine, it drips about once every 5 seconds. so it looks like a new hydro shaft seal is needed. my flex joints look to be in good shape so I will reuse them, it has 2 at each end of drive shaft.
when I unbolt the seal housing from the hydro is there anything I need to watch out for. like needle bearings and such. I have never had to work on the hydro in any of my tractors.
I am also tryin to find a service manual for the 1811.
Old 05-26-2012, 02:09 PM
Exclamation
found my parts I need on the cub web site, new seal, needle bearing, and o-ring will all be around $40.
while looking up parts I saw the charge pump kit, I think to myself, over 1000 hours why not change it and not have to worry.
Well I changed my mind real fast when the price came up at over $500 for it.
I could buy another 1811 for that price............
Old 05-26-2012, 02:41 PM
Hate hearing about the leak. Here is a link for a Service manual.
Section 3 covers the trans and hydro system.
http://ccmanuals.info/pdf/CCC%20GT%2...e%20Manual.pdf
