Old 05-29-2012, 12:34 PM
toinewi toinewi is offline
Default New to OCC, question on CC 125 Hydro fan shroud
Hello all, and thanks in advance for any help you can provide.
I've had a 125 for a little over a year now, and it's run like a champ. This month I got permission from the wifey to look for a different mower so I can start restoring my 125. I think it made the 125 jealous. The Hydro fan shroud came loose and rattling around if I try starting it up (I only tried starting it once, heard the rattle then found out that the shroud was loose).
Any advice on how to go about re-securing it? Can I do this from underneath or do I have to start taking things apart from the top?
Thanks in advance.
ToineWI
Old 05-29-2012, 12:51 PM
I've never seen one in person before but I bet you could bolt it back up with a lock nut. You will have to do it from under the tractor.
Old 05-29-2012, 09:42 PM
Welcome!!!
The shroud is attached by 4 screws.The heads of the screws are slotted and are located on top of the frame in front of the seat.The shroud has 4 clips one for each screw,but they may be missing.Pictures would help.
Up to 534 and counting...
Old 05-30-2012, 10:06 AM
You guys nailed it. The four screw holes (visible from the top of the 125's frame) are indeed missing screws. Hoping to remove the deck and take a look underneath today. Thanks for the quick answers!
Tags
125
