Old 06-16-2012, 09:35 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default 50 C Deck Refinish
Well over the past couple of weekends I have spent many, many hours cleaning, sanding and putting POR-15, primer, paint and clear coat on the deck. Here are a ton of pics so that you can see the full impact.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 06-16-2012, 10:04 PM
MrGitrdone41's Avatar
looks great!
1988 1812,dual ports
1973 108
1968 125
Old 06-16-2012, 10:28 PM
Nice job!
Old 06-16-2012, 10:45 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
looks good, but por-15 is for clean metal. it'll prob separate from the old paint and rust in a year or so.
Doug
Original , 100 , 125 , 582
Old 06-16-2012, 10:52 PM
Beautiful work BIGMOZEKE
Old 06-16-2012, 11:14 PM
Great job!
Old 06-17-2012, 09:52 AM
BIGMOZEKE's Avatar
Hey Doug,
I had read the directions very thouroughly and contacted POR before I did any of this work. The real purpose for the POR 15 is "Paint Over Rust" and that is what I primarily used it for on the underside and the to middle "business section" of the deck. What you can't see from the pictures is I had actually use the POR Metal prep per the directions as well. It is hard to judge how much of that coating you will need from the can, so once I had coated the areas that I had intended to coat to activate with the rust, I jjust kept on going. Figured that if a thin coat of paint lasted 30+ years, this extra measure of protection certainly not hurt. I work with several guys that use this stuff all of the time and they do not take any of the precautions that I have and all have had success with it and none of them use the Metal Prep at all......lucky if they even used a wire brush. I completely sanded the underside and the top rusted sections down as far as I could before treating and then coating.
Joe
1200 Puller[/U][/B]
1864
Old 06-17-2012, 12:08 PM
MWShaw's Avatar
MWShaw MWShaw is offline
Looks awesome! You obviously enjoyed doing it, so why don't we swap? Then you will have one to do all over again!!!!!
Ha Ha. J/K I need to do mine.
Old 06-17-2012, 12:19 PM
Big Mo
Need directions to your place. Gonna bring you a few 60" decks to refinish.
Nice work.
Old 06-17-2012, 12:23 PM
BIGMOZEKE's Avatar
You guys are riot.......you are welcome to come over and I will help you.....but ...you need to provide the Jose Cuervo........Bud Light...or other.........gonna warn you.....it won't be cheap.
Joe
Joe
1200 Puller[/U][/B]
1864
