Old 06-18-2012, 09:15 PM
122cub 122cub is offline
Default 1250 wiring
I just recently got a 1250 with some wiring issues, it first was just the ignition system but the further I dig the more twisted and taped wires I find. I've gotten the points coil and charging system rewired and attempted to start it. The mower turned over fine then all of the sudden nothing. I've gotten the trusty test light and volt meter out and went to town. I found that I'm getting current to the push button starter and it will carry current across the switch until you hook it up to the activation post on the solinoid. So I thought maybe that was my problem so I took it of cleaned it and hooked it up to the batt charger and made sure it was activating and it was. So next I was curious to see if I touched the hot lead to the starter lead if it would turn over and no luck terminals are clean and it has 11.82 volts to the lead. So now I'm puzzled I can hook the starter lead to the batt charger and ground it and it will turn over but won't off the hot lead can put the batt in my 122 and it will start I cannot figure my problem out I need some tips or advice I'm really wanting to use the tractor to mow with but can't get it to turn over any help would be appreciated
Old 06-18-2012, 09:34 PM
Well for starters (no pun intended), a 1250 is not supposed to have a push-button starter switch, so who knows what all else has been modified. I'd head over to the tech library, grab the wiring diagram, and put back things the way they should be and check your grounds. For what it's worth, 11.8V is a pretty weak battery. A fully charged battery should be ~12.5-13V or so.
Old 06-18-2012, 09:51 PM
I forgot to say that at the battery I'm 12.75 volts. And I didn't think that they came out with push button start.
Old 06-19-2012, 09:17 PM
I figured out my voltage issue it had a bad positive cable put a new cable on and finished the wiring and what do ya know she lives very loud with the muffler that is on it right now but she does run now all I gotta do is button it up and mow super excited
Old 06-19-2012, 09:41 PM
PaulS's Avatar
PaulS PaulS is offline
Having just been through an electrical problem I know how it feels when trying to locate but also know how it feels when everything works.
