Old 08-12-2012, 08:46 AM
Sugarmaker's Avatar
Kevin,
Thanks for posting a picture of the new 169. Yea it sounds like a project but with some time money and patience I am sure you will have it looking good.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 08-12-2012, 11:24 AM
If you need a good frame, the one I have in the for sale section is in pretty good shape. Josh is right, mine needs some TLC to be correct, but its a start.
Old 08-27-2012, 10:38 AM
ksanders ksanders is offline
Here’s a tractor that was beat to death over its life and about ragged out brought back to life. I bought a headlight panel for it now, just have to paint it and get it together. Just wanted to get it together since my decals finally came in. I doubt I keep this tractor as it was all about the refurbishing for me.
Parts Replaced: Frame due to multiple cracks in the front, back, and even in the middle. Dash tower due to heavy cracking at the base. Rear end was drilled out in several mounting holes and replaced. Wiring harness was cut up. Used but original style seat.
Parts that were missing completely and I added: Gas tank and straps, mower deck, subframe and mule drive assembly, side panels and hour meter, amp meter, hood hinge, generator and old style flywheel, backing plate, and cover. Also regulator.
Work done: 3 layers of paint from past “repaints” stripped, primed, and painted IH colors. New decals, new coil/condenser/plug/point/wire. Carb soaked and rebuilt. Took motor apart (also switched it back to 169 style generator, flywheel, dipstick, etc.). New rear end gaskets and seals etc. Front pto turned down in lathe, new fingers, thrust button, disc, and brass pto button. Replaced frame/rear end/wiring harness/dash tower/ more. Tapped all holes in frame and bolts for ease of removal and installation now and in the future. Tubes in 3 leaking tires. Disassembled and readjusted brakes/ clutch pedal/ hydro linkages. Welded up holes in the mower deck and readjusted the whole deck. New deck belts.
Preserving history... one Cub at a time.
Old 08-27-2012, 10:40 AM
And a few "semi-finished"
Old 08-27-2012, 10:44 AM
IHCUBCADET's Avatar
IHCUBCADET IHCUBCADET is offline
Nice job, what a difference!
International Cub Cadet 71 with deck
International Cub Cadet 108 with plow, deck, chains, single bottom plow,Sleeve Hitch.
IH Cub Cadet 122 project
Case 444 withs ags, plow
Old 08-27-2012, 10:45 AM
thats a really nice 169 nice work
Old 08-27-2012, 11:20 AM
Nice job Kevin!
Old 08-27-2012, 12:44 PM
Excellent job on the 169, Kevin!
Old 08-27-2012, 07:22 PM
IHinIN IHinIN is offline
Nice work! It turned out great.
Old 08-27-2012, 10:05 PM
ajgross ajgross is offline
Inactive Member
Kevin the 169 turned out great like all the others you do. Did you find a k341 for it or does it still have the k301?
AJ
