Old 08-25-2012, 03:22 PM
IHCUBCADET's Avatar
IHCUBCADET IHCUBCADET is offline
Default Clutch issuse on a 108
Went and pulled today at county fair, loaded tractor (cub108) up noticed clutch was gettting harder and harder to push in. Got it home now I can even ush it in at all to where the pressure plates pull appart. bfore I go pulling the engine and all, does anyone know what happened. Just want to know if this is a common problem. Thanks
International Cub Cadet 71 with deck
International Cub Cadet 108 with plow, deck, chains, single bottom plow,Sleeve Hitch.
IH Cub Cadet 122 project
Case 444 withs ags, plow
Old 08-25-2012, 08:23 PM
Merk Merk is offline
Any work done done lately to clutch before the pull?
Project Uncle Dick
Cub Cadet 70
Old 08-25-2012, 08:43 PM
IHCUBCADET's Avatar
Nothing Recent. About 2 years ago I put on the red spring. I dont know about all the pieces parts, but I assume the part on the shaft that pulls the pressure plates apart must be worn?! I do not know for sure.
Old 08-26-2012, 08:41 AM
mickb72 mickb72 is offline
Default clutch
Hi, maybe your clutch hanger is flexing,may need a support piece put in place. Mike
Old 08-26-2012, 11:36 AM
How much horsspower does your 108 have?
You don't need the red spring in a tractor that has under 20 horsepower and is use for daily use. I would use a blue spring form Cub Cadet Classics http://www.cubclassics.com/. He is one of our site sponsors. Another option is to use a cultivator spring that was talked about in another topic.
I have a cultivator spring in a IH Cub Cadet 100. The engine is making 14 to 16 horsepower. There is no slipage in the clutch and it is easy on your leg.
Odds are your clutch hanger is flexing....red spring cause the problem. Another area to look at is the area where the throwout bearing rides. That area may have some wear in it.
The clutch adjustment nut may be moving. I have to use a jam nut on my 100 to keep from turning.
Project Uncle Dick
Cub Cadet 70
Old 08-28-2012, 03:50 PM
IHCUBCADET's Avatar
When I push in the clutch, the top bracket that the clutch arm mounts onto, (that is like a bridge that goes from one side of the frame to the other, moves a little bit.... I will post a pic of the shaft so you guys can tell me if anything is missing/worn.
Old 08-28-2012, 03:53 PM
IHCUBCADET's Avatar
Ok, I looked up the part after writing a terrible explanation above. Yes then the hanger is flexing.
Old 08-28-2012, 04:28 PM
IHCUBCADET's Avatar
Default Which way is right?
The spacer is one way on parts tree.com and another when I took my clutch apart. Which way should the spacer be at the end of the shaft.
Old 08-28-2012, 04:59 PM
TommyK's Avatar
TommyK TommyK is offline
The picture on the left is correct. Should be the opposite of how it's shown on the parts tree diagram. The cup part of the spacer should go over the teaser spring. Found that out the hard way.
Old 08-28-2012, 05:27 PM
IHCUBCADET's Avatar
Good, cuz I got tired of waiting and went with my gut. I tried the wrong way first but found it to be unreasonable. I put this whole clutch back together and now it compresses without an issue, didnt change anything....go figure. I imagine it will happen again....
