Old 09-17-2012, 04:51 AM
cdlong's Avatar
cdlong cdlong is offline
Default Couple of problems with rebuilt 1450
Engine runs good, but seems to be running hot. Spark plug base is blue. I have good air flow across the head. Engine runs on after switch is turned off. Have very little throttle, almost no mid range. Seems to go from 700 rpms straight to 3600+ rpms. Hoods won't aline on either 1450. Had both dashes and grills off. Grills are positioned as far back as they will go.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 09-17-2012, 07:14 PM
cdlong's Avatar
Timing was causing the overheating problem. Still have trouble with throttle, goes from 540 rpms to 1640, then 1740, then 1800, (double readings, has a Tiny Tach). No mid range. Spring is in 3rd hole from bottom on gov lever and 2nd hole down on throttle lever.
Papaw
Old 09-17-2012, 09:40 PM
Donovan M.'s Avatar
the spring on the govnor is suppose to be on the second to last hole. and on my 1250 the spring to the the top hole on the throttle plate
Donovan:
62' Original-fenders
Old 09-18-2012, 03:50 AM
cdlong's Avatar
Thanks Donovan. I'll change them tonigth if it stops raining.
Papaw
Old 09-19-2012, 03:56 AM
cdlong's Avatar
That cured the problem. Thanks again Donovan.
Papaw
