Old 10-26-2012, 10:18 PM
Very sharp 100! I really like your tire combo!
Old 07-01-2013, 11:15 AM
markmdz markmdz is offline
I know this thread is 8 months old since it's last post, but being that I'm fairly new here, just came across this thread, and 100's are near and dear to me, I've got to bump the thread back up to find out how this beast fared with pushing the snow around this past winter.
Very very nice job bringing this thing back to life.
Do you plan to restore the rest of the tractor, or just leave it as is?
What are the stubs for sticking out of the rear wheels in the last set of pics?
Old 09-23-2013, 09:51 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Markmdz, I'm sorry for the very late response. I haven't been around for a while (new baby!). It did fairly well pushing snow this last winter ('12-'13) as long as it wasn't too deep. The current setup is 90 lbs. of weight off the wheels on each side and my 175-ish lbs. on the seat with the ags aired down a little, not sure of my pressure reading. Anything more than 4-5" of the wet heavy stuff it didn't like, or anything over 10" of standard snow it didn't like either. I scraped down to my concrete driveway each time I plowed so the tires being able to grab onto the brushed concrete surface sure helped. It was a bit harder to plow back to my shed over the yard - had to take smaller runs at it.
Thank you for the kind words. Its a work in progress, very much a worker tractor. It's nearly ergonomically perfect for me, so its very comfortable to use for long periods of time.
I do plan to fully restore it, not to showroom level, but a nice everyday usable level. I have a number of options I'd like to add or build for it yet, then I'll go about making him look pretty again.
The stubs sticking out of the rear wheels. They are a pair of old ruined coarse splined axles which I cut the splines off, drilled out the lug holes and put on backwards to hang my weight lifting style wheel weights on. It makes the little guy look more like a big tractor too. The axle stubs stay on all the time as they don't stick out past the ends of my 42" deck.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 09-23-2013, 10:10 PM
litlmikeyl's Avatar
Default New parts!!
Ever since I got the tractor back together, I haven't been able to get it to run right. Throttle was pretty touchy with little control past 2000 RPM. Thought something inside the motor broke, so I pulled the motor to find that to be false. Was able to fix my oil leak though. Reset my governor at least 4 times, still no avail. Finally figured out how to tune my carb - EUREKA!! Runs like a swiss watch now. Very,very pleased I must say.
Got some new parts too. A standard canister-style muffler w/elbow, a new mount for said muffler, a Kirk Engines-style breather and a new steering column bushing.
The plate for the breather looks like its purple 'cause it still has the red Dykem on it from when it was made. I'll paint it at a later date.
A gentleman at work (I work in a medical machine shop) was kind enough to cut me a custom bushing out of Radel plastic which is close to IH yellow in color. Fits my goofy sized column tube to perfection!
Currently working on a swinging-type grill mesh & a backrest with plans courtsey of Mr. ACecil.
New pictures too. Enjoy fellas.
Mike - Ramsey, MN
'65 100 - #126432
