Old 10-27-2012, 09:18 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default I Need a Welder
Working on a Model 149. The hydro pump was leaking from both sides of the trunnion shaft, so I decided to split the tractor and pull out the pump. I plan to change all four seals.
This is the control side of the trunnion shaft. It has the typical wear seen on these tractors
I'd like to do this job correctly while I have it apart, but I do not own a welder, I do not have access to a welder, and I do not know anyone who welds.
Maybe someone on this site can help me out with this. I would be happy to pay.
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 10-27-2012, 09:25 PM
Try Jeff in PA one of the members on this forum
Old 10-27-2012, 09:26 PM
TheSaturnV's Avatar
I see momma was gone to the store while you photo'ed tractor parts on the kitchen counter.
My MiG is down or I would step forward for you.
Old 10-27-2012, 09:31 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
x2 I to was going to say Jeff in PA
Doug
Original , 100 , 125 , 582
Old 10-27-2012, 09:37 PM
Nice work table. Talk about upscale. I'm still using an old steel work bench.
Old 10-27-2012, 09:41 PM
SharkyOhio's Avatar
For the record, I did wipe the Hytran off before I laid it out on the granite
Thanks for the quick responses! I will try to track down Jeff in PA.
Old 10-27-2012, 11:03 PM
PM'd with price and my address. Just weld the corners and make them square again?
Thanks
Jeff
Old 10-28-2012, 06:51 AM
Vince_o Vince_o is offline
Call Jeff or send it to me I do them all the time.
Disclamer welders arnt cub related
Old 10-28-2012, 12:30 PM
Shaner Shaner is offline
go to tractor supply and get one of those JobSmart 110 flux core mig welders....some times they are on sale for $110 something dollars. they arent all that great but it will do the job and do other jobs for you. or save your pennys and buy a nice millermatic mig or lincoln or esab mig.
Old 11-03-2012, 09:58 AM
Frank
Ive done worse, Ive done better. I didnt get to it yesterday with the mig so I had to use my off topic stick welder. Youll be fine and Kathy will get it in the mail to you monday. Our post office is closed on Sat due to their cut backs.
Oh and I really should charge you for this job, not for the labor, but for that horrable sound of the file on the steel! Man that make my hair stand up!!!!!!!!!!!!!!!!!!!! LMAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Im glad I could help you out.
