Old 11-10-2012, 03:16 PM
Is part # 27 in yours? That is a relief valve.
Old 11-10-2012, 03:38 PM
Clyde67's Avatar
Clyde67 Clyde67 is offline
Thanks AJ. I just picked up the tractor. No clue what's really in it. I plan in flushing it all out, but before I do that I'd like to figure out this leak.
Old 11-10-2012, 04:13 PM
Clyde67's Avatar
#27 is in it.
Old 11-11-2012, 12:48 PM
Clyde67's Avatar
So I took the line off and there is a hairline crack under where the clamp sits. Now onto finding solutions!
Old 11-11-2012, 01:14 PM
Clyde
I checked the Cub parts site, they have the line in stock.
Part #727-3067 $50.99
Think you told me you live in PA. if so I'd give these guys a shot.
http://www.messicks.com/
Or try the sponsors at the top of the page.
Old 11-11-2012, 03:36 PM
Clyde67's Avatar
Sam, thanks. I did see that. I'm going to try a local place first that makes hydraulic lines. I've heard they do good work and while you wait. I'll let you know how I make out.
Old 11-11-2012, 08:05 PM
Clyde67's Avatar
Just an update. While I'm working on getting a new line I drained out the Hydro Fluid and figured I'd share some of the photos.
This is the sludge that came out looking like caramel. No clue what fluid they had in there.
This is how the rear looked before I cleaned it out. Plenty of sludge and gasket sealer from the last time this was opened apparently.
All cleaned up!
Going to let it drain at least overnight and get the cover back on.
Old 11-11-2012, 08:15 PM
Good man. Re-fill it like I told you and run it for a few hours and do it again and then put the good stuff in unless you are like me and plan on changing it every year. The Hy-Tran is awesome at holdin water. If you change it one a year it is a waste of $$$.
Old 11-11-2012, 08:21 PM
Clyde67's Avatar
Sam, definitely following your advice.
I bought some of the stuff from NAPA to flush it out. Then, when I was at the Cub dealer for some of the other parts I needed I picked up the Cub fluid. It's a ways away from here to get to a Case dealer.
The Cub stuff gonna be OK?
Old 11-11-2012, 08:34 PM
Cub stuff is the same just WAY more $$$$ cause it comes in a Cub bottle. Gotta love it. The American way.
