Old 12-04-2012, 06:43 PM
bluesman bluesman is offline
Question Soaking up info
Friday, .I brought my new (to me) 1650 home and since then I've been reading all the posts I could find on the Quietline series. I'm hoping to make myself aware of the common problems so I can be at least a little pro active. So far the biggie seems to be the ISO engine mounts. I'll be checking mine asap. One post mentioned using straight pulleys in the mule drive instead of the angled ones. I'm going to need some help with that one. Can someone explain the difference to me and why it matters? Chewed up belts were mentioned............I hope to avoid that. Any and all help greatly appreciated.
Old 12-04-2012, 07:30 PM
Straight angled pulleys were used on the 38, 42, & 48 inch mower decks.
Angled pulleys were used on the newer 44 & 50 inch mower decks.
Old 12-04-2012, 08:10 PM
You may have already seen some or all of these, but here they are just in case.
Quiet Line Links:
Download and print all the manuals;
Carb Rebuilding: http://mgonitzke.net16.net/tools/carb_rebuild.pdf
ISO mount and snubber: http://www.onlycubcadets.net/forum/showthread.php?t=7
Hydro Filters: http://www.onlycubcadets.net/forum/showthread.php?t=12
Ignition Circuit: http://www.onlycubcadets.net/forum/showthread.php?t=27
Ignition Coil: http://www.onlycubcadets.net/forum/showthread.php?t=11
Spark Plug Chart: Use Autolite: http://www.onlycubcadets.net/forum/s...ead.php?t=4638
Static Timing for new points: http://mgonitzke.net16.net/tools/static_timing.pdf
Chassis Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Kohler Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4646
1650 Operators Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4670
PTO adjustment: http://www.onlycubcadets.net/forum/showthread.php?t=30
Wiring Diagrams: http://www.onlycubcadets.net/forum/showthread.php?t=22
Cradle Mod: http://www.onlycubcadets.net/forum/s...ead.php?t=4630
Old 12-04-2012, 09:19 PM
Thanks for the information. I have a 50 inch deck and so I quess the mule drive I have is for that deck. I bought the tractor more for the tiller and blade than the mower deck. Will the mule drive I have be alright with the tiller?
Old 12-04-2012, 09:26 PM
You need the 38/42 mule drive for the tiller.
Old 12-04-2012, 10:18 PM
Thanks, Methos. How do I identify the 38/42 mule drive? How are the two different?
Old 12-04-2012, 11:49 PM
They are the same mule drive. They will not have any angle to the pulleys. With you having a 50" deck you need the angled pulleys for that so I would not try to straighten the mule drive. When I was looking for mine I placed a want ad in the wanted section of the site and was able to get one shipped to me for $45. I tried modifying a 50 mule drive but broke the belt after 10 mins of tilling. That was a $65 mistake.
I'm going to move this to the attachment section as we've veered into that direction.
Old 12-05-2012, 10:10 AM
Thanks again, and my condolences for your short lived belt. I'm going to assume that the angle in the pulleys is enough to see so I can tell whether or not I have the angled one. Can I also assume that the 50" deck can be run with the straight mule drive so it's possible I already have the straight one? I ask that because the PO obviously used the tiller as it still has dirt on the tines. I don't want to make a 65.00 assumption, however.
Old 12-05-2012, 11:41 AM
Post a pic of your mule drive. The 50" uses angled pulleys. I still cry over that first belt.
Old 12-05-2012, 08:53 PM
Methos. Here are a couple of pics of my mule drive. After looking at it again I think I see the angularity on the pulley with the J bolt used for adjustment......is that correct? Thanks again.
Tags
1650 iso mule drive
