Old 04-06-2009, 01:09 PM
weaverama weaverama is offline
Default Any secrets to swapping Lift Valve?
After a couple weeks of trying to unstick the lift valve assembly on my Quietline, I give up and have located a good used unit. What am I up against when I remove the hydraulic lines? Is oil going to fly everywhere? Will there be air introduced to the system? Will I need to add oil and purge the air? If so, how so I do this? I did a search in the technical library but could not find out answers to these questions. Maybe I am thinking too much but it seems to me, unless the new lift valve is full of oil, there will be air introduced and that can't be good. If anyone can help me out I'd appreciate it.
Rich
Old 04-06-2009, 01:24 PM
You'll lose some oil, but not an appreciable amount. Simply operating the hydraulics after installing the valve will work out any air trapped in the system.
Old 04-06-2009, 01:27 PM
young enthusiest's Avatar
I have a suggestion. if you are taking the valve out to replace it, put it in a vice, and hit the valve with a hammer. if it breaks, get a new one like you planned. if it works, you saved a bit of money and time. just my $.02
Old 04-16-2009, 03:16 PM
Just my luck, the day the replacement valve arrives my stuck valve breaks free. Good ol' PB Blaster.
Old 04-17-2009, 10:17 AM
Hehe! good to hear you got it working. now do you want to send the spare valve up here???
Old 04-17-2009, 02:11 PM
I sent you a PM
