Old 03-06-2013, 04:11 PM
cub123's Avatar
cub123 cub123 is offline
I use a old manual bead breaker and a set of TSC tire irons. Takes about 10-15 min a tire. I would rather change two sets of rear tries than one set of front ones though... As far as beading a tubeless tire I put a ratchet strap around center of the tire and tighten it up a little then bounce the tire on the ground a few times and put some air in it, once it starts to bead remove the strap and finish beading it.
Old 03-06-2013, 05:25 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
It worked for my V61s! http://www.onlycubcadets.net/forum/a...hp?albumid=507
Old 03-07-2013, 06:24 PM
Grampie Grampie is offline
Default Big tires
You guys haven't lived till you have changed a few of the tires for these toys. I don't miss those days at all, thank you very much.
SAM, How about BIG, STINKY TIRES on a Garbage Truck? Does that count? Usually inside rear!
Old 03-07-2013, 06:43 PM
I'll pass, I've done a 12.00 X 24 split rim inside on a loaded concrete truck on a 100 degree day and that was enough for me. Add in the smell from a grabage truck and I think I would puke.
Old 03-07-2013, 09:12 PM
EricR's Avatar
EricR EricR is offline
Originally Posted by PaulS View Post
Bill that little tire changer sounds like the ticket but it also sounds like others have more of my redneck approach. You know what I mean, one of those, Here hold my beer, stand back and watch this" approach.
Yeah and the bad part is he has driven the truck each and every time and I seem to get stuck on the dirty end! I don't mind as it has saved us a bunch of $$$$$$$$$$.
And Sam I have changed a bunch of tires on my old tri-axle and agree I don't miss that kind of work either.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
