Old 04-01-2013, 02:07 PM
cheifsix's Avatar
cheifsix cheifsix is offline
Default Kohler 321 14 hp
I have a Kohler K321AS with spec. # 60279d that is blue. The #30 carb has been broken off but is still there and the dipstick and cam cover are missing.
Questions:
1) Is there any difference between a #30 carb for a 14hp vs. a 16hp?
2) Does anyone know what the motor may have come out of (I'm assuming a Ford LGT-145)?
3) Will this fit a cub the same as a Kohler 14hp from a cub (i.e. is the only difference primarily the crank?)?
Matt Shockley
Barksprings Ridge Farm & Antiques
1967 102,1967 125,1969 104,1970 106,1970 107, 1970 126,1971 126
Brinly: 10" plow, 3 discs, box scraper, cultivator
1963 Sears Suburban 725
Case IH c50 w/ Woods DuAl Loader
Old 04-01-2013, 06:06 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
the #30 used on the 14 is a 15/16 venture while the ine used on a 16 is a 1 in venture
crank and oil an could be different. a 1450 use's the K321AQS
Old 04-01-2013, 11:15 PM
cheifsix's Avatar
Thanks. That helps.
Matt Shockley
