Old 04-10-2013, 11:32 PM
Cjbdvm04 Cjbdvm04 is offline
Default Crankshaft end play.
I'm getting ready to rebuild my newly machined k301. I realize that there are crank end play specs but how do you measure the end play since the crank bearings are tigh on the crank and also tight on the block (pto side) and in the bearing plate? I'm not sure if I'm being clear with my question. I guess my question is: Can the crank be moved freely in the axial dimension once the bearing plate is tightened?
Old 04-11-2013, 12:25 AM
samiam44 samiam44 is offline
the simple answer is YES. Measure it with a dial indicator. You shim using gaskets- more/or less!
The bearing/crank can move in the case and on the crank/bearing journal too. The ball bearings are not that tight of a fit-
Put it all in spec and it will run great! Cam too- there are shims for that also.
Michael
