Old 04-28-2013, 12:11 PM
cclemen2 cclemen2 is offline
Question LT 1042 Extension Spring
All,
I've got a 2006 LT1042 with the cutting deck that has two large extension springs. One of the springs broke off and I need to replace. It's the spring that attaches to the bracket assembly. I have the new part and am having a bear of a time stretching the spring to connect the two ends. Any thoughts or tricks to this?
Thanks in advance,
Old 07-27-2013, 07:46 AM
Khackee Khackee is offline
Default Tip
I use either a long philips screwdriver or a set of automotive brake spring pliers. Brake spring pliers work the best, can be had at Advance auto for about $10
Old 07-27-2013, 10:20 AM
Good advice!
Tags
install, lt1042, springs
