Old 05-11-2013, 08:17 PM
nel606 nel606 is offline
Default 782 Hyrdo Quit Running
Hello, I was cruising along on my first mowing of the year when the engine just stopped as if I had shut off the key. I tried restarting for a couple minutes with no luck. Then the starter stopped working. When I turn on the key, there is nothing. No lights, the hour meter doesn't run and the amp meter doesn't move. The battery is fully charged, and if I jump the solenoid the starter turns over the engine, but there is no spark at the plugs. I am hoping I've missed something obvious (it has fuel). If you have any ideas, I am open to suggestions.
Thank you!
Old 05-11-2013, 08:21 PM
Fuses....check the fuses....
Old 05-11-2013, 09:23 PM
Default Are there more than 2 fuses
Thank you so much for replying. I've checked the two fuses in the attached picture for continuity. They both seem to be all right. Are there any other fuses or relays I should be checking?
Old 05-11-2013, 10:17 PM
mlhsierra99 mlhsierra99 is offline
check the pto switch. sometimes i have the same symptoms with my 682 and a simple on/off with the pto switch brings it back. not saying you have the same problem, but its worth a try.....
Old 05-11-2013, 11:10 PM
dale c. dale c. is offline
check the ignition switch and harness ,try wiggling the connector while trying to crank it over
Old 05-12-2013, 12:12 AM
105_Tom's Avatar
105_Tom 105_Tom is offline
I'm having the same on going issues with my 782. It's in the connector at the ignition switch - there is a loose connection or short in there somewhere with the black wire on the right side of the harness connector. Be careful, because there are wires in there that are hot all the time - make sure you use insulated pliers if you are poking around in there. Remember, heat = resistance, so the problem may get worse when the tractor is hot. Keep probing and you'll find the weak spot!
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 05-12-2013, 08:29 PM
Default Success!
First, thank you all for your suggestions. I was ready to start taking things apart and tracing wires. I cannot say exactly which issue was the problem, either the key switch has a intermittent short, or one of the fuses was not making good contact in its holder. I shot some contact cleaner and scrubbed in the fuse holders with a small wire brush (from a gun cleaning kit). I also hit the back of the key switch with the contact cleaner as well. Everything is working well now. Thank you all again!
Old 05-12-2013, 09:42 PM
Glad to hear you got it all worked out!
Old 05-12-2013, 09:50 PM
Good news
Nothing worst than chasing electrical problems.
Old 05-12-2013, 11:17 PM
Awesome news!
