Old 05-20-2013, 09:10 AM
CUBDRIVER75's Avatar
CUBDRIVER75 CUBDRIVER75 is offline
Default Best model's for pulling?
I know gear drive is the way to.What about NF vs WF ect...???
Original, 70,2284
Old 05-20-2013, 10:11 AM
brad.bristle99's Avatar
brad.bristle99 brad.bristle99 is offline
personally I like the narrow frame better because they are simpler and easier to work with.
Old 05-20-2013, 10:27 AM
ajcombs's Avatar
ajcombs ajcombs is offline
I like the look of my (NF) 100 but find that the wide frames are easier to work with, but I do not do pulling, just workers here.
Old 05-20-2013, 08:02 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I would have to say one of the early narrow frames before the quick attach, but if you really have your heart set on a 124 or 126 then use the early tall tunnel frame. or just have some frame rails bent up. save's you the work of welding up all the unwanted holes.
Old 05-20-2013, 08:13 PM
I would think a removable tunnel cover is important to service the clutch.
Old 05-20-2013, 08:53 PM
dvogtvpe's Avatar
if you put good clutch parts in to start with there's no service to speak of. 2 years ago I changed a clutch disc in a guys pro altered V twin in a half pint chassis in 20 min. He was the first hook and smoked the clutch disc bad. had a 5 puck clutch in it. apparently his adjusting rod had come loose and tightened up the free play. He was able to come back and finish 3rd . The thing that's really important in choosing which chassis to use is how they hook up, when it comes to that its a NF then a WF then a 82 series. you can make tunnel covers removable, you can make it very easy to work on clutch's or remove a engine or rearend. I can have a rearend or motor out of my tractor in 5 min. with an electric impact in hand. its all in how you build it.
Old 05-20-2013, 09:51 PM
austin8214's Avatar
Don does it help to brace the frames on the 82 series tractors?
Old 05-20-2013, 10:28 PM
dsams dsams is offline
To many people get hung up on what style frame hooks the best, and forget its more about knowing what your tractor will do, in '07 a WF was the ticket, now it's a NF. Personally I don't think it really matters. Started out with a 106 NF stock tractor won a couple local points championships with it. Moved up to sport stock running both the 106 and a 1200 won points championships with both tractors. Now running 582 stock altered tractors on the nqs widest of the wides and my father is leading the points in the 1050 class won 2 of the last three pulls and got 3rd the other time. Being able to read the track and knowing what your tractor will do means much more then if you are running a NF or WF.
Old 05-21-2013, 08:46 AM
Sounds like pick a style and go with it,and not worry too much....
Original, 70,2284
Old 05-21-2013, 10:57 AM
That's right.
