Old 06-18-2013, 07:14 AM
I had the same issue with my Vaguard. There is a diode in each wire that goes to each mag. Go to Radio-shack and get 2 $2 diodes and put them in each kill wire. The ones I picked up are rated at 1000 volts @ 1.5 amps. The new harness that came with my mags didn't have them in either. The diode keeps them from grounding each other out.
If you do this make sure you get the diodes in the correct direction. Diodes are a one way check valve for electricity. Perhaps Todd can post what way they go.
Old 06-18-2013, 07:42 AM
Yep, the stripe on it goes on the side that connects to the mag. The part number I used was 276-1114.
