Old 09-01-2013, 09:07 AM
Joetotleben Joetotleben is offline
Question 125 Hydro selector handle removal?
I am trying to swap out the dash tower on a 125. I can not figure out how to remove the hydro selector lever. Is there a set screw or something that holds it on? Under the handle it looks like there may have been a hole but i am unable to access it.
Old 09-01-2013, 09:22 AM
YES, as per the Parts Manual: Screw, 10-24 X 1/2 Hex Soc Hd Half Dog Pt Set
Old 09-01-2013, 12:07 PM
Once you remove the screw,shoot inside it with some PB blaster, it may take a few tries.
Up to 534 and counting...
Old 09-01-2013, 12:28 PM
Yea the hole looks like they may have put jb weld or something similar in it, over top of the screw. Thanks for your help! Now just to figure how to get that out....
Old 09-01-2013, 06:55 PM
dgrapes59 dgrapes59 is offline
As noted the parts manual shows: 10-24 X 1/2 Hex Soc Hd Half Dog Pt Set
Couple questions...
Is this a hex head bolt that extends out of handle and what does the last part of the description mean (what type of fastener is this, anyone have a picture)? It appears this may be broken in the handle, the bolt is basically flush with the handle.
Thanks all,
(Joe's hydro ignorant helper)
Old 09-01-2013, 07:15 PM
Couple questions...
Thanks all,
It's a socket head set screw. The tap drill for a 10-24 is a #25 drill ( .1495)
The correct allen wrench size is 3/32
Old 09-04-2013, 11:09 PM
Ohhhh ok well then that bolt IS broken off flush with the handle. Perfect! LOL Thanks for your help guys
Old 09-05-2013, 09:20 PM
A stick of dynamite can also be used to remove that handle.....On second thought, better not!
Just having some fun...
Old 09-05-2013, 09:26 PM
No, the set screw is like this
There may be crud in the hex but I doubt it's broken off.
Old 09-05-2013, 11:09 PM
TheSaturnV's Avatar
Even with the set screw gone, mine still need a bit of heat and a mallet to be persuaded off. Take your time.
