Old 02-28-2010, 05:32 PM
dads70's Avatar
dads70 dads70 is offline
Default anybody know if the model 86 ever had a lift?
was there a 3pt lift for a model 86 cub cadet? i haver a awesome 86 been in family since new with all books, but id like to put a lift attachment for a plow on the rear did they ever have one as an add on?
Old 02-28-2010, 06:23 PM
Yep, the 86 used a sleeve hitch. You can hook a plow to it, along with other implements.
Old 02-28-2010, 08:52 PM
Merk Merk is offline
Any hitch from a wide frame or Quiet Line Cub Cadet will work.
Wide Frame models are 86-108-109-128-129-149-169.
Quiet Line models are 800-1000-1200-1250-1450-1650.
Old 02-28-2010, 09:22 PM
MBounds's Avatar
MBounds MBounds is offline
All right Guys!! Sleeve Hitches and 3-point lifts are not the same thing and some of you know it. Please use the correct terminology. How else are the new guys going to learn??
1) A sleeve Hitch is found on the tongue of a plow or other implement!
2) A Sleeve Hitch Adaptor allows you to hook that implement with a Sleeve Hitch to a Cub Cadet.
3) An IH 3-point lift will allow you to lift that plow (or other implement) for transport.
Myron B
CCSupplyRoom
Old 03-01-2010, 03:31 AM
ajgross ajgross is offline
Inactive Member
Dale don't forget that the later Quietline hitches used frankenstein bolts and not rod that the 86 uses.
AJ
Old 03-01-2010, 03:43 AM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
AJ
Unless you do like I did and welded the spacers into the frame holes so I could use the same setup as older frames. It's kinda weird,as my 1200 sisn't have the spacers but the other 1200 we parted had a set. They were only a couple months apart too...
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 03-01-2010, 07:28 AM
MBounds's Avatar
AJG: Please read my post above!. Those "frankenstein" bolts are used on the lift arm of the 3-point lift and have nothing to do with any hitch...Puhleeze!!...
Myron B
