Old 09-30-2013, 09:05 PM
bocephus1991's Avatar
Default From a 1211 into a 1282 main harness wiring
Did some research this evening into how to wire up my 1211 that I am putting a k301aqs into. I bought a 1282 ignition switch installed it and got my battery and test light out and started checking things over. Heres what I came up with,I was using my 1200 as a guide .looks like it may be easier than I thought! (crossing my fingers)
1st on the left,orange wire has no pwr
yellow wire key on pwr ,crank it goes dead
bottom right two white wires key on pwr,cranking has pwr
second pic on the right
top wire is black or blue key on pwr crank pwr goes to coil
bottom wire key on pwr,crank goes dead.
Do I just wire into the 1211 harnnes using blade connectors and hook it up like my 1200? And forget about the orange wire?Looks like it would work just fine. Was funny had an engine block on the seat to get it to crank mode and brake locked down!
File Type: jpg 1211 1200 main harness wiring to engine.jpg (10.4 KB, 46 views)
Brian
Old 10-01-2013, 11:08 AM
Sorry, I don't know what I'm looking at. What are the two connectors you pictured for?
It should be pretty easy to figure out. Get the '82 series diagram here... 82 Series wiring diagram
Get the 1211 chassis service manual here..... Chassis Manual
The wiring diagram is on page 2-55
Print them both out, and go from there.
Old 10-01-2013, 09:08 PM
The left picture is of the main harness connector that goes to the engine on the 1211 the right is of my 1200 with a k301,which is the same engine that I am putting into my 1211. I have the diagrams saved on my pc,will give the links you posted a look,sorry to be confusing and long winded!
Brian
