Old 10-02-2013, 08:22 PM
jmature jmature is offline
Default 1450 - 1650 carb?
does the 1650 - k341 use the same carb as the 1450 - k321?
thanks for any info
Old 10-02-2013, 09:56 PM
thanks for any info
No, they are different.
Part numbers for carbs.
47-853-20 = 1450
47-853-29 = 1650
Old 10-02-2013, 10:27 PM
IH Cub Cadet IH Cub Cadet is offline
For some reason I'm thinking the K321 (14 hp) and K341 (16 hp) engines used a Kohler Carter #30 whereas the K301 (12 hp) and K241 (10 hp) engines used a Kohler Carter #26 carb.
Not sure what the Walboro carb's would be.
Take the above info with a grain of salt.
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 10-03-2013, 02:14 AM
cubby102's Avatar
cubby102 cubby102 is offline
Pretty sure the carb bodys are pretty well the same it was the jetting that was different.
Old 10-03-2013, 02:40 AM
Part numbers are different, so.... wouldn't that be a not the same carb?
Old 10-03-2013, 02:44 AM
cubby102's Avatar
Zippy depends on if the new carbs come with jets or not.my guess is they do and the different numbers tell em which jets to put in. But I could definatly be wrong. Would be willing to see the main differences
Old 10-03-2013, 02:54 AM
Makes sense, so the carb body is the same except for the size of the jets?
There was a pretty big gap in the price of one over the other.
Old 10-03-2013, 03:53 AM
cubby102's Avatar
That's just my guess I could be wrong. And more then likely am. I'm sure someone will check out exactly what the difference is.
Old 10-03-2013, 08:00 AM
bocephus1991's Avatar
the k301 an k321 use the same the k341 is a dif part number,like others have said prob the dif is the jets
Brian
Old 10-03-2013, 09:11 PM
rweaver rweaver is offline
I was told by a carb guy the 30mm on a 321 the bore was smaller than the 30mm on a 341 did I measure one no but this was a puller who rebuilt carbs for guys
