Old 10-30-2013, 02:21 PM
782CC 782CC is offline
Default Pondering a new backside
Just picked up a 2072 to go with my H48 thrower. No rear hitch. Turns out the front PTO has issues as well. Anyway. I do have an extra sleeve hitch that I could use but it has the aluminum rear. Since I happen to have a parts 1250 sitting there I am wondering about the pro/cons of changing them out. I would like the additional weight of the cast. And I would feel more manly too. lol
I need to make the rear and front operate separate. Appears the frame is quite different and no material in the upper frame for Frankenstein bolts. Saw a blade mod on the site with a upper cylinder that i can operate with aux hyd. So really only need the lower mount on the sleeve hitch system right now.
Or should I just bite the bullitt and pick up an extreme 3pt that I want anyway...
Old 10-30-2013, 03:29 PM
Call Bill Ruegg and put the correct hitch that is built every bit as well as the extreme but cheaper and a lot heavier. Make sure the 6 bolts holding the rear are in good shape and if you can put one of Sam Macs rear brace kits on it. If you go cast Iron on the rear you need to change the guts out for it to work properly. There is nothing wrong with well maintained aluminum rear.
Old 10-30-2013, 03:58 PM
Thanks- I should have searched more before asking. A ton of info about it here.
Old 10-30-2013, 04:57 PM
Oak gave you some very good advise. If you do as he suggested you will never bust the rear in that tractor plus you will be able to do more with it than a sleeve hitch setup.
Old 10-30-2013, 11:25 PM
Yeah it is really want I want anyway. Just looking for short term that would get me up and running for snow. Was not aware of others making the 3pts. It will have summer duty of keeping up with a few farmalls so plan to work it from time to time.
Old 10-31-2013, 09:09 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
I bought a set of sams braces. Worth the money. Very nice machine work!
1- 1200 in pieces
1- 1864 in pieces
