I noticed that one of the grease zerks is missing on the front axle of my 782. I've never had a cub with them missing before. How do they go in, and where do you buy them? Would Tractor Supply have them? Thanks guys!
Just screws in.
Original, 109, a pair of 122s, 124 with power lift, 124 with creeper, 126, 147, 1050, 1200, two 1250s, 1450 Dual Stick , another 1450, two 1650s, Gannon Earthcavator, Haban sickle bar and a bunch of other things you either pull, push or hang underneath. |
Also, what's the correct size for them? Sorry for the question, but with my sight, they are hard for me to see.
If its missing... it could be broken off...you will need to easy out the old one and re-thread the hole and the new zerk will thread in easy
I think they are 3/16 Allen and it's been awhile since I messed with one but I think they are press in too.
This from the Cub parts site. Grease Fitting, 3/16 Part Number: 737-3000
Yes they are a press fit.
Remove the spindle and knock the remaining piece thru.Then put the new one on.
Any good hardware store or farm supply should have some
122 PTO, lift, deck, weights, and chains clist pick 123 headlights no motor came with the 122 Stx38 free acquisition but its the wrong color works great though Free craftsman gt 17hp Briggs Intek hydro |
One place I remember seeing zerk fittings was at a place here in Northern Minnesota, I just happened to stumble upon them. It was a fleet supply place and they actually had this outside along with a lot of other newer Cubs and different brands. You can probably find them at a fleet supply place if you have any North Carolina.
I'm glad this topic came up, because I have an axle that was missing a grease zerk on the right side. It did not have one. I had to drill a hole thru tap and install one.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
