Old 12-10-2013, 12:12 PM
jimbob200521's Avatar
Thanks for the suggestions, guy! I haven't had much time to work on it in the last couple days but I did at least check the fuse and it appears alright. I want to take a closer look this weekend and make sure I'm getting 12v and good ground along with checking out everything else you all suggested. I'll post back as soon as I find out more, thanks again guys, y'all are the best!
-Ryan
Old 12-10-2013, 07:01 PM
Red face
While checking the 12volts, use an older analog meter or test light. Sometimes the high impedance of the digital meters don't have enough circuit loading to accurately read the voltage,particularly if poor connections are involved.
Never mind HOW I know...I just know
Old 12-11-2013, 09:48 AM
Well, update time: I went out to the garage last night to put new skid shoes on my blade and decided to take a look at the 682. I checked to make sure the PTO 12v wire was connected, started it, and violla! PTO worked, and worked, and worked. Left it run for about 35 minutes and kept flipping that switch; worked every stinking time. I even turned it off and was able to flip the switch and hear the "click" several times. I'm going to be so angry if that was it Not really, I'd be glad if it was something so simple, but time will tell. Now to mount the blower back up to it. I'll update if anything changes but I've got a weird feeling it's not going to be that easy
-Ryan
Old 12-11-2013, 11:17 AM
Glad to hear all is well with the 682!
