Old 12-11-2013, 05:05 PM
vartz04 vartz04 is offline
Default More snow plowing with the 104. Pics this time
Did the 2 driveways today. As weird as it sounds running the ags works so much better than the turfs and chains.
Also wanted to see what she could do in the snow. Climbed this hill like it was nothing.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 12-11-2013, 05:31 PM
Great photos of a cub having fun in the snow. As far as tires, it really depends a lot on the surface you are on, as well as other factors, like tire pressure, hardness of the rubber, loaded tires and weight distribution, etc. On ice or icy packed snow, the chains really do work well, but I have spun both ags and turfs 'n chains on ice before.
Old 12-11-2013, 06:03 PM
Agreed. The slope at the front of my drive is the worst part. With the blade up driving up the hill or backing up the hill with the chains I would just spin and slowly make progress. This was a test after adding the weight bracket and fluid filling the tires.
With 8-10PsI in the ags I can go forwards or back on snow covered pavement some of which is packed down from car tires and not spin. I haven't even fluid filled them yet.
Old 12-11-2013, 06:33 PM
Cool snow pics
Old 12-11-2013, 10:03 PM
Great snow pics!
Old 12-11-2013, 10:06 PM
Thanks. Wouldn't mind some heavier snow though do I could feel that old thumper work.
Old 12-12-2013, 12:11 AM
Great plowing pictures, thanks for sharing
Old 12-12-2013, 12:57 AM
Userj8670's Avatar
I hear that but just be happy you have some snow! I'm at 9 degrees and still not a snow flake in sight!
Old 12-12-2013, 10:02 AM
Rdrnek Rdrnek is offline
Thats a hill? Here In Pennsylvania that would just be called a little bump in the yard! I had to put ags on my 149 just so I can cut grass.
I grew up in Ne Ohio I miss the Flatlands . Great plowing pics
-Bob-
149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104
Old 12-12-2013, 10:43 AM
Its steep not high. I fell down it the other day grabbing firewood because the snowy slope is not possible to walk across. Heck I Can't even walk up it if it's snow covered but the cub rolls right up.
If this was a forever house I'd build a retaining wall 6-8 feet off the garage and put a stone pad over there and a shed. And a staircase down to the garden.
