Old 12-13-2013, 08:18 PM
c69ss396 c69ss396 is offline
Default What is the best tires for snow use...??
What tire would be the best for snow duty? They both will be weighted and have 2 link snow chains.
Old 12-13-2013, 09:09 PM
turbo460 turbo460 is offline
The ones on the right.. IMHO
Old 12-13-2013, 09:28 PM
I have ran both in the snow before and the ones on the left don't hold the snow as much as the ones on the right, since it has channels and not "pockets". Of course the chains are going to give you grip for either one, but without the chains, I have always had better traction with the left ones.
Old 12-13-2013, 09:46 PM
gmbadgley gmbadgley is offline
With chains you shouldn't notice any difference between the two since the traction is from the chains, not the tire tread.
"If I can't fix it, I can screw it up so bad no one else can either"
Old 12-13-2013, 10:07 PM
As it was said above, both tires would be equal since you said you were putting chains on them...
Old 12-13-2013, 11:38 PM
I guess I'll run the newer style "turf" tires since they have almost no weather damage to them...
Old 12-14-2013, 05:41 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
Both are good. With weight and chains
Doug
Original , 100 , 125 , 582
Old 12-14-2013, 07:55 AM
My vote is left. Narrower tires are preferred in snow. Plus the tread pattern looks better IMO.
