Old 01-04-2014, 09:13 PM
Wes1200cub Wes1200cub is offline
Default Cub 1200
I'm new to the forum here and also new to Cub Cadets. I just recently picked up a Cub Cadet 1200. It's had the engine rebuilt and runs great. It also came with a mower deck. What I'm wanting to know is where can I find a sleeve hitch and plow for it. I am wanting to use it to plow my garden. Any responses will help a lot being that I'm clueless. Thanks in advance.
Old 01-04-2014, 09:26 PM
Welcome Wes
You will need a rear lift, a sleeve hitch adapter and plow. I would also suggest either ag tires or chains on turfs plus wheel weights.
I make heavy duty sleeve hitches and other parts.
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Jeff
Old 01-04-2014, 09:46 PM
Sleeve hitch adapter
Lift pin that fits in the rear lift casting
Not sure if you need this for the rear casting pivot. If the holes are 7/8" you need "Frankenstein bolts". If they are 5/8", then a rod is what you use
Here is a picture of Narrow frame ( you have a wide frame and they will be slightly different ) rear lift parts plus a spring assist
click for bigger picture
This is the type of plow you want to get
Old 01-04-2014, 11:45 PM
Welcome to OCC! Place a wanted ad, in the Wanted Items section of the site. You can also check with our sponsors at the top of each page.
Old 01-05-2014, 07:18 AM
Originally Posted by Wes1200cub View Post
I'm new to the forum here and also new to cub cadets. I just recently picked up a cub cadet 1200. It's had the engine rebuilt and runs great. It also came with a mower deck. What I'm wanting to know is where can I find a sleeve hitch and plow for it. I am wanting to use it to plow my garden. Any responses will help a lot being that I'm clueless. Thanks in advance.
Welcome to OCC!
Old 01-05-2014, 08:15 AM
Welcome to OCC.
Old 01-05-2014, 01:27 PM
Wow thanks a lot this definitely helped me out a lot. I appreciate the help and I'm starting to love this cub.
Old 01-05-2014, 01:31 PM
Welcome Wes
Jeff
So your sleeve hitch adapter is what I need plus bolts. Then all I would need is the plow?
Old 01-05-2014, 01:49 PM
Do you have a rear lift? ( the casting with lift bar that connects to the lift handle or hydraulic cylinder )
Can you post pictures of your 1200?
Old 01-05-2014, 02:26 PM
Similar to this
