Old 02-10-2014, 07:04 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Default Hood Catch
After getting the 102 refurbished and painted I wanted to do something about the hood opening down on the grille. So first I moved the voltage regulator down on a rubber mount. Then I drilled and tapped a 1/4" hole in the top of the grille casting to bolt a small hook to. The next piece is mounted to a lengthened rear hood ornament bolt. The hood piece has a small hook on the end to catch the smaller hooked piece. No more marring the grille paint and denting the hood .
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 02-10-2014, 07:28 AM
MWShaw's Avatar
MWShaw MWShaw is offline
Nice job!
Old 02-10-2014, 07:59 AM
Muzzy Muzzy is offline
Yeah, that's nice. I'm surprized IH never did anything about that.
Old 02-10-2014, 09:04 AM
Nice job!
What they said.
Old 02-10-2014, 10:35 AM
Nice work and a great idea!
Old 02-10-2014, 12:08 PM
IHinIN IHinIN is offline
Nice work. I'll have to make one of those when I repaint my 100.
Old 02-10-2014, 06:20 PM
Nice work!
Old 02-10-2014, 08:41 PM
EricR's Avatar
EricR EricR is offline
Nice work!
What Mike said.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 02-11-2014, 12:11 AM
What they said
Old 02-14-2014, 04:50 PM
john hall's Avatar
Great idea!
