Old 03-23-2014, 08:47 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
You could use that same set up, almost to make a pto bearing puller too.
Tubing that is just big enough to go over the bearing. With cross holes drilled in the end that would be behind the bearing. Holes would allow you to slide three pins or bolts thru the tube so that they are passing in behind the bearing.
hen that same bar and bolt on the outer end.
Been messing with my pto bearing on the 127 trying to get it off. The pto pully wobbles so I am thinking the bearing needs to be replaced. To Harbor Freight tomorrow after work to find a puller that won't bend and maybe is short enough that I won't have to pull the cast iron grill holder.
Old 03-30-2014, 06:21 PM
This came in the mail from Jeff in PA. A well made tool.
It worked fine removing the type that are pressed on,the ones that are spot welded needed the slide hammer.
Gotta work on that Jeff.
Up to 534 and counting...
Old 03-30-2014, 06:35 PM
Looks like milling four notches will correct the problem.
Old 03-30-2014, 07:45 PM
Looks good lew, Jeff , great work as always.
Old 04-06-2014, 05:18 PM
More "betterer" ?
Headed your way tomorrow
Old 04-06-2014, 05:40 PM
More "betterer" ?
Good job, Jeff!
Old 04-06-2014, 06:50 PM
Nice work Jeff.
Old 04-06-2014, 07:40 PM
Methinks it will work fine.
Old 04-07-2014, 03:43 PM
Looks good Jeff! When does it go into production?
Old 04-07-2014, 07:44 PM
When it gets the Lew seal of approval
