Old 04-07-2010, 01:47 AM
JayBrd's Avatar
JayBrd JayBrd is offline
Default Cleaning ID Tags
Anyone have a "trick" for cleaning overspray from the ID tags on decks, ect. that will not wreck them?
Jay N.
Eau Claire, WI
RED 82 Series...
Old 04-07-2010, 02:25 AM
cubby cubby is offline
id like to know also but can say this no acetone i made this mistake and whiped the id plate on a motor bare a few years back
Old 04-07-2010, 05:51 AM
Acetone works real good, and in some cases too good. I would try Lacquer Thinner in a test spot and see how that works.
Old 04-10-2010, 01:57 AM
nix1650's Avatar
nix1650 nix1650 is offline
lacquer thinner is just as bad as acetone . if the overspray is from a rattle can try wax and grease remover (eg ppg dx 330) put some on a rag and rub it on the overspray. if the over spray is from a catylized paint (eg if it was sprayed with a paint gun and used a hardener) nothing will take it off without destroying it.
Old 04-10-2010, 03:06 AM
When I used to work for Dana we put grease on the ID tags before the axles and transmissions were painted. We would then wipe away the paint and grease. Once wiped the ID tags would be perfect.
Old 04-25-2010, 08:56 PM
brad121075 brad121075 is offline
I use denatured alcohol to remove paint from prefinished woodwork. Ive never used it on a ID plate but maybe try it in a small spot and see how it works.
Old 04-26-2010, 01:47 PM
BanditCub BanditCub is offline
I used lacquer thinner, it was the only thing that would touch it. If you're careful and work quick it works fine, just be sure you remove it all before you walk away.
Red '84 Cub Cadet 782
50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd.
Old 04-30-2010, 11:56 AM
johncub7172's Avatar
What about trying some Fast Orange hand cleaner?
Old 04-30-2010, 12:09 PM
methos109 methos109 is offline
Soft scrub may work as well.
