Old 04-10-2014, 11:26 AM
j elliff's Avatar
j elliff j elliff is offline
Default Manual PTO bearing replacement
I've looked here for a bit and couldn't find exactly what I was looking for. Can someone here please inform me as to how I'm supposed to go about correctly installing the PTO bearing onto the shaft. Having the snap ring on there I can't seem to install it. I understand it is supposed to be tight but holy moly. I've smacked it with a block of wood and hammer and it just won't go. I'd appreciate info as to how you guys have done this in the past.
thanks, Joe
livin the cub life
Old 04-10-2014, 02:38 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Locking collar should slide onto shaft, the stepped edge facing you.
Bearing should go on fairly easy as well.
I just did mine and I might have had to thump it with hammer handle but no hammering it on.
Bearing only goes on until flush with end of shaft.
The snap ring is in the pto bearing bore.
I have never had to replace that though.
Old 04-10-2014, 04:25 PM
j elliff's Avatar
Yes. That is where my issue lies though I believe. The new bearing I am installing has a snap ring which is not expanding to allow bearing to be flush with the end of the shaft. I suppose I did not pay enough attention when I pulled the old one off but I believe it was flush as well with the snap ring over expanded versus snap ring bottoming out at end of shaft.
livin the cub life
Old 04-10-2014, 04:30 PM
j elliff's Avatar
in the picture above it is bottomed out to the snap ring. I would say that it's leaving 1/16" to being flush. Old bearing and new bearing are identical and correct for the 127.
livin the cub life
Old 04-10-2014, 04:49 PM
DoubleO7's Avatar
My 127 does not have any snap ring touching the shaft.
The only snap ring I have is inside the pto pulley assembly that will go over the bearing in your pic. It stops the pto pulley assembly from sliding too far onto that bearing.
Old 04-10-2014, 05:41 PM
Lets see a pic of the "snap ring". I don't see one in the pic. Are you talking about the locking collar?
Old 04-10-2014, 06:28 PM
sawdustdad's Avatar
I have had PTO bearings with the snap ring on them, too. I put the bearing on until it touches the snap ring, then installed the locking collar. No problems so far. (this is not the same snap ring as the one inside the PTO.)
Old 04-10-2014, 06:31 PM
Is it an internal snap ring on the OD of the bearing?
Old 04-10-2014, 07:21 PM
j elliff's Avatar
The snap ring is on the ID of the bearing sleeve. It's very thin and as such hard to see in the picture. I will take some more pictures of the bearing then tonight when I get back home. Thanks for the help so far
livin the cub life
Old 04-10-2014, 07:49 PM
Why not just take the snap ring off.....
They are removable.
