Old 04-27-2014, 09:48 AM
habitat0789 habitat0789 is offline
Default Cranks and sparks but no run. 1811
Hey guys, this is my first post after i have been lurking for about a month now.
Recently acquired my fathers 1811 that he purchased new in 1990. some of my earliest memories are riding this thing around the lawn. he got a zero turn a few years back and it has been sitting for probably 2-3 years. got a new 18hp kohler a few years before it was retired to the shed
Now that i have some grass of my own i offered to take the old 1811 hydro off his hands.
when i got it back to my place i was having trouble getting it to crank. changed the solonoid and ignition switch only to find that it was the brake safety that was hitching up that 12v signal. Now i can get it to turn over no problem with the key.
However nothing fires. it just cranks. i had changed the spark plugs so i tried the old ones. still nothing. cranked it with the plugs removed and arked them onto the frame, and they are sparking.
after cranking the starter for probably longer than i should have gas started dripping out of the front mounted muffler. which i assume is just because its getting pumped through the engine sans combustion.
Its possible that the engine is now flooded exacerbating my problem? i am curious if a simple blast of starting fluid in the right place would get it kicking or if there is anything to get that first fireball to emerge. if anyone has a pointer to help send me in the right direction i would really appreciate it.
its spring and the grass is growing.
Old 04-27-2014, 11:17 AM
It takes four things to make combustion
(1) Fuel
(2) Air
(3) Spark
(4) Compression
YOU say you have fuel, spark, and air, so it might be you have less than the minimum compression to accomplish combustion.
Old 04-27-2014, 12:16 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Possibly a weak battery.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 04-27-2014, 12:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
if you didn't rebuild the carb you will want to do that. it could be flooding due to a leaking needle and seat. flooding put out the fire. also clean the tank out and use fresh gas
Old 04-27-2014, 01:31 PM
The M-18 is Magneto Ignition
Old 04-27-2014, 01:42 PM
jimbob200521's Avatar
Smell your oil and report back.
-Ryan
Old 04-27-2014, 01:44 PM
the battery is brand new and the gas is fresh premium no ethanol with fuel stabilizer.
you may be right about the carb. i noticed a little gas on it after i worked it over with the starter. I assume that is evidence of some improper function. i will look into rebuilding the carb. good advice!
Old 04-27-2014, 01:47 PM
oil fill hole smells like gas...
Old 04-27-2014, 01:52 PM
Time to rebuild the carb, and possibly replace the fuel pump.
Old 04-27-2014, 03:27 PM
Beat me to it! But you're right, rebuild the carb and possibly replace the fuel pump.
-Ryan
