Old 05-05-2014, 01:57 PM
jimbob200521's Avatar
Default Oil Cooler
Just a random thought that came across my mind the other day while working; has anyone out there ever put an oil cooler on any of the Cubs equipped with a remote oil filter? It would slightly increase capacity, if done right it would help the engine to run a bit cooler, and should extend oil life, even if not by that incredoubly much. The only real concern I could see is is the oil pump sufficient to pump through the extra line/radiator? What do you more experienced guys out there thing?
Edit: Something as simple as this:
http://www.amazon.com/Derale-13730-E...ote+oil+cooler
As for where to mount it, I'm not 100% sure. Between the front grill and engine? This is more about would it be worth it rather than where would it mount. Like I said, just a thought.
-Ryan
Old 05-05-2014, 02:29 PM
Ryan,
If you were to mount a cooler, it would have to be behind the engine near the flywheel where the fresh cool air is. You can't put it up front as the air up there is hot, plus the fan on that unit you posted a link to would melt up there. Someone here tried something like that already.
There was an oil cooler available for the CH engines, that is just like what I mentioned. I don't have time to look for it right now, but it's out there. I'm not sure if there was one available for the Mag's or not, but it's dooable.
Old 05-05-2014, 03:57 PM
CAO65 CAO65 is offline
I looked into this back when I had an 1863 and posted a similar question on this forum. The tractor was running very hot, and I didn't know why. I later learned through posters on this forum the tractor was running lean. Google "oil coolers for Kohler Command engines," and you will see how they are put on the engine. Part of the shroud covering the shaft/flywheel area is cut out, and the cooler attaches to the side of engine tins and partly inside the shroud to get the cooler air. It should be noted some larger Cub Cadet zero turns may have them assembled already. Since I got the GT2000, I have not thought about it as engine does not run hot.
Old 05-05-2014, 07:37 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Check this site out
http://www.mytractorforum.com/showthread.php?t=137335
