Old 05-21-2014, 10:05 PM
It is actually the generator that is being polarized. Any time the battery, V/R, or S/G is disconnected the generator needs to be polarized.
I have never done this and ever had a problem.
but there is always a first time.
Up to 534 and counting...
Old 05-21-2014, 10:31 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Lew, your a lucky guy in a lot of ways!
Let me correct myself. It may not need to be done, but should be done.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-21-2014, 11:24 PM
I have no idea what you're even talking about.
What is it and how do you do it? Why is it important?
Old 05-21-2014, 11:46 PM
jrob33 jrob33 is offline
Originally Posted by lynco View Post
Thanks for warning me about Re-polarizing... I didn't know. I'm reading how to in the test Rouland suggested above. Am I reading it right? A short jumper between the B & G terminals on the V/R ?
I just recently did the same troubleshooting. Quick post with a couple pics. Mine is a 149 though. The tech section here and Roland are the way to go!
http://www.onlycubcadets.net/forum/s...ad.php?t=31329
Old 05-31-2014, 02:40 PM
lynco's Avatar
lynco lynco is offline
Finally got the old girl charging again. I don't think I needed to replace the voltage regulator, I believe what did the trick was just cleaning up all the connections around the regulator. Live and learn.
Old 05-31-2014, 04:38 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
actually if you look through the schematic all the way when you start to crank, it self polarizes itself. that's why you should never really have to do it
Old 05-31-2014, 11:33 PM
Good to hear!
Old 06-01-2014, 09:47 AM
Good job on getting the Cub rolling again!
From what I have seen here, most electrical problems ( short of someone hacking the wiring harness ) are due to corroded connections.
I have sometimes seen crimp terminal connections where the wire has corroded away from the crimp, and the wire is only holding on by a crimp on the insulation.
Only thing better than having a Cub Cadet is USING one
Old 06-01-2014, 05:27 PM
Great news!
