Old 06-16-2014, 10:33 PM
Kratt's Avatar
Kratt Kratt is offline
Default Differential Removal
Ok fellers. Need some help. I need to replace 2nd gear in my 126. I have the rear end completely apart, but for the life of me I cannot get the differential out of there. No matter what angle i come at it. Any tips on getting that thing out?
Members of The Herd
149 Restored: Tilling Machine --- https://www.onlycubcadets.net/forum/...ad.php?t=27758
126 Restored: Just too pretty to use --- https://www.onlycubcadets.net/forum/...ad.php?t=32695
104 As Is: Snow Pusher.
102 As Is: Snow Thrower.
123 Currently Under Construction!!! --- https://www.onlycubcadets.net/forum/...ad.php?t=55593
Old 06-17-2014, 07:17 AM
mickb72 mickb72 is offline
Default cub
Hello, got to hold your tongue just right. ha ha The ring gear side comes out first.(verticle with a little tilt to 1 or 2 oclock) It helps if you have the big bearing off the left side. Mike
Old 06-17-2014, 01:55 PM
cubby102's Avatar
cubby102 cubby102 is offline
Ive had luck getting them out with a little fenagling and some choice words. It does help if you can get the bearing off
Old 06-17-2014, 04:28 PM
Kratt's Avatar
I tried the tongue and the choice words...neither seemed to do the trick.
In case i destroy the bearing trying to get it off, are they available aftermarket? I looked and couldn't find any left in stock at the usual places online.
Members of The Herd
