Old 10-02-2014, 04:13 PM
Originally Posted by dvogtvpe View Post
torque the brass nut? I've never done that before. I just use common sense tight.
I didn't know it had a torque..... Shouldn't be surprised. Everything does.....
Old 10-02-2014, 07:59 PM
OldCubby OldCubby is offline
The governor is fixed and worked like a charm! the tab did need to be pointed down when installed and then I went through the procedure to set it.
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 10-02-2014, 09:18 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
years ago I helped write a manual for a military truck (PLS) they built. I did the engine section. when ever they asked what the torque is on a bracket or a cover I'd say common sense tight. their response was always "We assume their is no common sense in the military"
realistically there's only 2 things you need to torque, rod and head. the rest are tight enough you don't strip them out and tight enough they don't come loose , I've been turning wrench's since I was 10.
Old 10-02-2014, 09:21 PM
dvogtvpe's Avatar
Originally Posted by OldCubby View Post
The manual calls out 100/120 in-lbs of torque for the bushing nut. I guess I use common sense if I read the manual
If I followed the Kohler manual I wouldn't be making the horsepower we are
Old 10-02-2014, 09:22 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I do intakes too. Especially aluminum.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-02-2014, 09:23 PM
I think he was referring to the "K" series Kohlers ......
Old 10-02-2014, 09:24 PM
dvogtvpe's Avatar
I was referring to Kohler.
Old 10-02-2014, 09:26 PM
Shrewcub's Avatar
That occurred to me the second I hit I hit submit.
Sorry, Don!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 10-03-2014, 05:51 AM
GOOD to hear.
Old 10-03-2014, 07:39 AM
dbuck dbuck is offline
Thumbs up
Glad to hear you have the gov'r problem straighten out. How is everything else working out on your newly restored 1250?
