Old 05-13-2010, 03:06 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default Hydraulic lines and hoses
I am getting ready to replace the hydraulic hoses and lines on my 1450. Can anyone tell me what size fittings to get for the connections to the hydro unit and lift cylinder? Also what size lines should I get 1/4 or 3/8? I am going to put a different spool valve on so that I can run the aux lines to the front and rear. Thanks in advance
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 12-20-2014, 06:40 PM
This is an old thread, but I have been curious about the same. Does anybody know the sizes of the hoses and the fittings that go into the lift cylinder or spool valve on a Quietline or 1x8/9 series?? I looked in the service manual but there is no info in it.
Old 12-20-2014, 06:53 PM
I used 3/8 steel brake line and 3/8 hydraulic hoses I made up with reusable parker fittings I had on hand
Old 12-20-2014, 09:55 PM
My 129 used #6 JIC on 3/8" hose.
