Old 11-10-2014, 11:29 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
They have to take the tire completely off the rim to add a tube?
Tire shops love not putting fluid in tubes because they can push one bead down and pour the fluid in over the bead. And blow it shut, both in about 5 minutes per tire.
Calcium corroding the heck out of a rim is due to metal exposed to the oxygen containing air inside the tire. Keep it full up so the rim never sees air and it will last long time. Or air up with nitrogen maybe.
Old 11-10-2014, 12:09 PM
Originally Posted by garnold View Post
So all this for $45 is not all that bad.
Gene, is that $45 total? Or per tire? Because you made it sound like it was per tire. If it's total, and includes the tubes in the price, then no that isn't bad. If it's per tire..... it's still a rip off.
Agreed, my shop only charged $34.15 for both of my rear 26-12x12 super tires, AND they provided the antifreeze.
Ben, that sounds very reasonable and more like what I would expect.
No, they should just have to take one side off the rim.
Yes to both of these statements!! Easier to put fluid into a tubeless tire. And if your not using CaCl2 I wouldn't use a tube. You are exactly correct about CaCl2 and air. That's what I keep saying. You can do it tubeless as long as the rim is submerged. I prefer tubes with CaCl2, but that's mostly just because if you ever need to change the tire it's less of a mess.
Old 11-10-2014, 10:04 PM
garnold's Avatar
garnold garnold is offline
Yeah, when I got the quote it was going to be $45 per tire. I didn't think that was all that bad because they said the tubes cost around $18 per but I guess maybe it is a little high?
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
