Old 12-16-2014, 08:39 AM
garnold's Avatar
garnold garnold is offline
Default HF Tractor Lift
Might pull the trigger on this one. Thought I would share.
Click Here
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 12-16-2014, 08:58 AM
Billy-O's Avatar
Billy-O Billy-O is offline
The lift would be pretty cool to have...... but if this thing is 300lb. lift capacity as the specs say,I'm ....not ... so ..... sure !!!!. It's hard to find any info on weight of the tractor but I found at least one info mentioning 650lb. shipping weight and that's without the implements.
Whatever you do, jack stands before crawling under
Plow blade
#2 Cart
QA36 snowthower
Old 12-16-2014, 09:07 AM
garnold's Avatar
Originally Posted by Billy-O View Post
The lift would be pretty cool to have...... but if this thing is 300lb. lift capacity (if I have the right one looking at HF), I'm ....not ... so ..... sure !!!!. It's hard to find any info on weight of the tractor but I found at least one info mentioning 650lb. shipping weight and that's without the implements.
Whatever you do, jack stands be crawling under
Bare with me here because I'm not a by any means a math wiz but since we are only lifting the front of the tractor wouldn't that cut down on the weight? Oh and I totally agree with you about the JACKS!!! Let's be honest here, you really want to put your life in the hands of a lift that's on sale from HF HAHAHAHA! Backup plan full in effect here!!!
73 WIP
75 WIP
Old 12-16-2014, 09:18 AM
Go get the bathroom scale, jack up the front of the tractor, slide the scale under 1 front wheel, lower the jack and see what 1 wheel weighs then double it and you'll know what your dealing with. Northern tools has jacks with higher weight ratings but also higher prices.
Old 12-16-2014, 09:26 AM
garnold's Avatar
And this is why I always tried to sit next to folks like Sam during my math tests at school!!!!
73 WIP
75 WIP
Old 12-16-2014, 10:42 AM
I think as long as your only lifting the front it will be fine, the rear end of the cub is where all the weight is at. I once stopped at a scale with my cub on and with all the wheel weights and fluid in the tires with the mower deck on it was right at 900lbs but as I mentioned most of the weight was in the rear.
Old 12-16-2014, 10:45 AM
PaulS's Avatar
PaulS PaulS is offline
I was thinking along the lines that Sam mentioned except my thought was raise the front, place a scale under the front, and use something like a piece of 2X12 and place it vertical between the tractor and the scale. Only problem would be if the front of the tractor exceeds the limit of the scale.
Old 12-16-2014, 10:57 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
My Dad got me one of these for Christmas last year. He got it somewhere else but it looks to be the same model. It will lift the 1864, but struggles. It does have a safety lock on it. Jack stands aren't a bad idea but can get in the way depending on wht you are doing.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-16-2014, 05:12 PM
Merk Merk is offline
The pictures of the 2 lifts scares me. I want someway to secure the front tire to the lift so it doesn't come out.
Project Uncle Dick
Cub Cadet 70
Old 12-16-2014, 07:06 PM
Shrewcub's Avatar
Gene I didn't look carefully at the one you posted the first time. I don't see a safety on that now that I look again. Unless you slide a pin through that hole.
You could use a small ratchet strap, but once it is fully lifted and the brake is locked, it's not going anywhere. I kinda see what you are saying on the one the PO posted with the adjustable pin for different size tires.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
