Old 02-06-2015, 09:54 AM
Default 125 project
well someone made it a 105.
i havent been in a big cub mood over the winter, they got jammed in various bits of the shop since my buddy got busy out there on customers cars.
this 125 i am fixing up to give to a good friend that appreciates old working stuff, he just joined here i think.
i bought the 125 from my neighbor last year, now i am trying to get it going.
the engine fired right up, sounds great! no smokeshow!
i move the hydro lever to see if the tractor moves, and nothing.
linkage is hooked up and i confirmed that it's moving the hydro shaft.
the driveshaft is also turning the pump.
i freed one of the hydro relief valves, i did it with long pliers, i did not split the tractor. both valves move with the release lever.
the rear is full, i filled it and no giant puddles.
could the filter be clogged? it's ancient!
i assume my neighbor parked it yrs ago cause it stopped moving. i did not bother to ask him cause his health is not good, he's got better stuff to think about.
i hear no humming from the pump at all.
also the fan on the driveshaft is broken off.
i would like to get this beast working before doing the paint job and replacing the missing engine tins, i also need to trade the later model deck on it to a 42" quick attach deck, the one on there is a quietline deck, looks like a 44".
Old 02-06-2015, 10:25 AM
Did you check to make sure the shaft going into the trans is turning, could be a broken pin in the coupler.
Old 02-06-2015, 10:52 AM
What Tim said, or the valves are not ALL the way up.
I've had valves that I thought were up but were not before and especially on a Narrow Frame, it's hard to tell.
If you are sure these things are as they should be, then the next step is a fluid and filter change, be sure to wash all the crud out of the rear end.
Old 02-06-2015, 02:38 PM
yes the shaft is turning the hydro pump.
Old 02-06-2015, 03:24 PM
i changed the filter, and now it moves under its own power.
the hydro lever is way out of adjustment.
Old 02-06-2015, 07:05 PM
Glad to hear that it was a simple fix and a needed maintenance remedy anyway. Looks like it is going to be a good cub.
Old 02-13-2015, 01:32 PM
johncub7172's Avatar
Hey, I'm glad to read you got this 125 going!
Old 02-13-2015, 08:57 PM
Love that seat. Any idea what it's from?
Old 02-13-2015, 09:16 PM
It reminds me of the one on my old Ferguson. Does it flip up backward?
I'm not intentionally trying to direct this thread in another direction.
Old 02-13-2015, 09:21 PM
yes it flips up backwards, and yes the neighbor has a MF loader........so that's where it came from lol.
