Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 02-17-2015, 05:45 AM
sbauerz28's Avatar
Default Kubota fuel lines
I took my injectors out last night so I can take them to town to get rebuilt. It doesn't look like they have ever been touched. Is there any special hose I should use to replace the lines that go from injector to injector? They are very hard and brittle.
Old 02-17-2015, 07:20 AM
Those are return lines so they don't see much pressure. I'd use what ever fits that is compatible with diesel fuel.
Old 02-17-2015, 07:22 AM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
Parts tree shows this # 3
Cub Cadet KB-15841-42500
Pipe, Overflow
Your price: $5.16
for the fuel line that goes from the last injector to the fuel pump you might be able to cross reference it with napa, or ur local Kubota dealer.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 02-17-2015, 07:25 AM
I'm preaty sure I did what Sam suggested, I took one of the lines to napa told them what ifs for n they set me up.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 02-17-2015, 07:42 AM
sbauerz28's Avatar
I actually was referring to the lines labeled #1 in the diagram above. My first thought was regular gas line. I just wasn't sure if it was compatible with diesel fuel. I guess I will stop by NAPA tonight and see what they have. Diesel shop told me 3 days for the injectors, so I hope to be back in business by the weekend.
Old 02-17-2015, 08:06 AM
Parts tree says #1 NLA, I don't know why. Sounds like seat time commin this weekend good deal. If u don't mind, let us know how much it costs to rebuild them. To replace them is $85 each.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 02-17-2015, 08:13 AM
sbauerz28's Avatar
That's what I seen, NLA. I think I will stop by NAPA tonight and see what they have. My only concern with regular gas line is it being compatible with diesel fuel.
Where did you find injectors for that price? The best price I could find was around $120. The diesel shop in my area, D&W Diesel, quoted me $70 each for the rebuild.
Old 02-17-2015, 10:48 AM
These guys are good.
This one is for the D600.
http://www.messicks.com/partsearch.a...1-53000&ven=KU
Looks like this one is for the D640.
http://www.messicks.com/partdetail/1...00.aspx&ven=KU
Double check me on these numbers. I've been wrong many times before.
Old 02-17-2015, 12:36 PM
Local Kubota dealer. 15841-53000 injector #
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 02-17-2015, 01:20 PM
gt383mag's Avatar
gt383mag gt383mag is offline
sbauer can i ask why your having them rebuilt what were the symptoms that made you have the rebuilt? just curious. my tractor starts much better with the block heater installed but have noticed that even when its plugged in for an hour i still need glo plugs for 15 or so seconds for it to start. dont make any sense because the temp gauge is reading a normal operating temp. i would think with the engine that warm it should fire without them not really sure but IIRC i think i need to use glo plugs in summer also does anyone else have this goin on is this normal?
