Old 02-25-2015, 09:14 PM
Tankman's Avatar
Tankman Tankman is offline
Default 1641 Sleeve Hitch & Hot Rods
Can't visualize too great, a sleeve hitch installation on a 1641.
1) What parts, all, do I need?
2) Diagrams for installation?
3) Perhaps a picture, or two, or three?
Be kind, new to Cubbies and grandsons 'n I need this (?).
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-26-2015, 08:44 AM
This is what Cub had for the 1641
http://www.partstree.com/parts/?lc=c...&dn=0064700001
This is the copy of it by Xtreme
http://www.xtrememotorworks.com/Part.../CC-03-001.htm
Old 02-26-2015, 09:10 AM
Sam, you have any sleeve hitch pics for an aluminum rear? I'm thinking that is what he's looking for.
Old 02-26-2015, 09:14 AM
Tankman's Avatar
Sam was thinkin' of an easy Brinley style hitch.
Does the flat plate simply bolt on to the yellow back where the height adjust turn screw is located?
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-26-2015, 11:23 AM
If you want to do a sleeve hitch you'll need to come up with some sort of a lift. I used a small winch on the back of this one with a sleeve hitch.
Old 02-27-2015, 10:25 AM
Tankman's Avatar
The black steel mount bolts onto the tranny? Parts from eXtreme?
Looks like a solution that I can live with.
I am looking at a 3-point used hitch complete. Are there instructions for installing 190-389?
Don't see where the bar lift hooks to the hyd lift? Or for that matter, where all this "stuff" bolts up?
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-27-2015, 10:51 AM
Thought I sent you the service manual? The instructions for installing the Cat 0 3 point hitch are in it.
If your going to do the sleeve hitch from Xtreme get the one that has the tabs that bolt to the axle tubes. Don't know if you installed a rear end brace on this tractor, if you did you will need to call Aaron when you order the hitch so that he can take that into account because the tabs will need to be moved outwards the thickness of the steel used for the brace. Just my 2 cents but if your going to use the 1641 for ground engaging tools I highly recommend that you put the GT brace on it. That 1572 in the pic I posted has the Xtreme sleeve hitch and the rear end brace on it.
Old 02-27-2015, 11:47 AM
Steve149's Avatar
Steve149 Steve149 is offline
Sam not to deviate from the thread but what lift is that you have in your shop for the tractors???? it is way too cool!
Old 02-27-2015, 12:01 PM
Steve
I have to thank Cubcrazy for finding the lift. Here is the thread he started about it.
http://www.onlycubcadets.net/forum/s...ad.php?t=22696
Here is a link to more info from the people that made it.
http://www.advancelifts.com/sitefile...t/at-1024.html
Old 02-27-2015, 12:21 PM
Steve149's Avatar
Steve
Thanks Sam...I will have to start scouring the CL listings to see if I can't find one someplace!
