Old 04-08-2015, 08:23 PM
Old Skool Old Skool is offline
Default ?? on a 2072
I finally got a 2072. Brought it home and gave it a good bath to start with. Found that the oil filter lines leak, starter needed removed and cleaned, front axle needs snugged up and new wheel bearings, plus the usual filter and fluid change. The foam piece that goes between the engine and the firewall is gone. Parts tree no longer carries this piece, can you get something at a hardware store to work or is it really necessary?
Thanks, Dave
Old 04-08-2015, 08:27 PM
Tankman's Avatar
Tankman Tankman is offline
Use a piece of hose or foam insulation; i.e.: thin pipe insulation.
Slice down the middle and put it on the steel.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 04-08-2015, 08:30 PM
That's not the right thing...... Your thinking of the piece that seals the tank support to the side panels and hood.
Yes, you can use foam from a hardware store. I'd suggest the square stuff with a sticky back like for sealing window AC units. Denser the foam the better. Yes, you need it. It keeps the fan pulling cooler air from the rear and not recirculating hot air from the engine bay.
Old 04-08-2015, 09:29 PM
Thanks J-Mech, also on parts tree they show 2 pieces,the upper and the lower foam pieces. Where does the lower piece go to/ get attached to?
Dave
Old 04-08-2015, 09:30 PM
It seals between the flywheel housing and the engine plate. Originally, it was "stuck" to the flywheel housing.
Old 04-08-2015, 11:21 PM
CTRUEX CTRUEX is offline
J-Mech is spot on, but I'd like to add that you want to use closed cell foam, open cell will trap moisture and promote bad stuff.
Old 04-09-2015, 05:07 AM
Tankman's Avatar
Thanks J-Mech! Still a newbie to Cubs, but, thanks to OCC, learning.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 04-09-2015, 06:38 AM
Thanks guys! Guess I will go to the hardware store and try to get some closed cell and also try to locate 2 new rubber grommets for the oil lines while I am there. Once I get her back together, I will try to get pictures on here.
Dave
Old 04-09-2015, 07:56 AM
Darrell Darrell is offline
What a bummer !! I ordered some of those strips just last summer , should have gotten more !!
Looks like the 1862 , 63 , 64 , uses the same thing but it is on the bottom , but it also says NLA after i searched the parts no.
Please LMK if you find a good replacement .
Thanks !!!!
Old 04-09-2015, 08:08 AM
Did some more lookin' and the 1861 and 1862 use that foam strip , but the 1863 uses a solid round foam piece , 723-3062.
Not sure if it would work , and partstree has it priced at $14.40. Maybe an alternative if nothing else can be found.
