Old 04-18-2015, 06:42 PM
jflaw92 jflaw92 is offline
Default 1200 problems
I have a 1200 that I've been having to use jumper cables to jump from the battery to the starter in order to start it, and it would start fine but today I took the electric clutch off and made sure it was good, found out it's not getting power to the clutch, and after I put it all back together the engine acts like it's locked up. I checked the oil and it is in between full and add so I would think that is the problem. I'm about to the end of my rope with this mower. Thanks for the help.
Old 04-18-2015, 06:56 PM
Check to make sure your wiring is hooked up correctly. Here's a wiring diagram from the resources here ( bottom diagram )
http://www.onlycubcadets.net/forum/showthread.php?t=22
Old 04-18-2015, 08:15 PM
If it spun fine before you removed the PTO clutch, but not after reinstallation the most likely cause is improper installation of the PTO.
On a second note, it is not necessary to remove the PTO to "check" it, unless you are checking the bearings.
Jeff is correct about checking the wiring. You DO have a wiring issue.
Old 04-18-2015, 10:33 PM
Ok thanks, the pulley on the pto seemed really loose so that's why I took it off initially. Thanks for the wiring diagram I looked on the Internet but couldn't find one thanks again.
Old 04-18-2015, 10:36 PM
Oh and by the way, just to make sure do any of you have a diagram for the pto? Just to make sure I put it on right, I'm almost sure I did but who knows maybe I forgot something.
Old 04-18-2015, 10:53 PM
Service manual:
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
It has wiring diagrams too.
Old 04-19-2015, 09:50 AM
sawdustdad's Avatar
If you reassemble the electric PTO clutch incorrectly, it will seem like the engine is locked up. BTDT.
Read the manual and follow the assembly sequence.
